630 Triple Range Question
Richard Lee
07-30-2006 19:44:58
It says in my ops manual that you should not use low range for heavy pulling, its a creeper range only. does the same hold true when using a front end loader when your trying to load the bucket. What good is low range if you cant use it as such. THANKS FOR ANY ADVICE.
Roger (Mi)
07-31-2006 05:08:55
 Re: 630 Triple Range low range in reply to Richard Lee, 07-30-2006 19:44:58
If a heavy load is put on a triple range in low range, the amount of gear reduction and torque put upon the transmission could cause damage (broken gear teeth). The low range is primarily designed for pulling PTO implements that need higher engine speeds but not higher ground speed (big windrows for a hay baler, etc.) Also, it's great for cultivation. Use (direct) for heavy work.
