800 case o matic
cassseee
07-30-2006 15:10:07
I have a 800 case o matic diesel. When trying to shift it into any gear, you have to grind it in. It does not seem to matter if you have just started it up, or have been working it all day. Is there something out of adjustment??
Thanks in advance.
Lincoln
07-30-2006 19:17:35
 Re: 800 case o matic in reply to cassseee, 07-30-2006 15:10:07
You have to switch gears with the engine idled all the way down. My 611B will grind quite a bit if you don't.
John Saeli
07-30-2006 16:12:31
They will do that. If it is a hard grind, so the gears won't stop, it could be a sign that the plates in the Converter are warped. Using the wrong oil could aggrevate it. At the time, CASE reccomended Dexron Type A. Todays Transmission - Hydraulic Fluids work well. I always start them in gear, & when changing gears, shift fast.
Good luck
