specs
johndeereman
07-30-2006 13:20:13
does anyone know what the valves are supposed to be set at on a 49 dc also what are the points supposed to be set at on a case mag i have a valve sticking i think it puffs some smoke once in a while is there an easy fix for this, tractor has been sitting for quite a while until just recently
dctom
07-30-2006 15:52:45
 Re: specs in reply to johndeereman, 07-30-2006 13:20:13
both valves .18 cold, mag the same suggest you use wd40 on valves with it runing to loosen sticky valves
