Case 2470 powershift seals (piston)
Mike S 806/H
07-29-2006 19:27:31
I purchased a caseIH seal kit for the powershift pistons, The seal kit has a different style seals then what my old ones are, the seal kit has a teflon looking seal that you have to use wire on the outer seals. My tractor has a square yellow color ring with a o-ring under it, Will this kit work with my pistons?
jim handke
07-31-2006 06:06:48
 Re: Case 2470 powershift seals (piston) in reply to Mike S 806/H, 07-29-2006 19:27:31
Grumpy"s right. The piston you have has a wider groove than the old style. And the kit you have is better than the old style by far.
Mike S 806/H
07-31-2006 21:11:05
 Re: Case 2470 powershift seals (piston) in reply to jim handke, 07-31-2006 06:06:48
Hi, Jim, what would I have to ask for at the dealer, a seal kit for a 4490??? my tractor is a 1973 so it must of been updated? Thanks, Mike
jim handke
08-01-2006 06:00:59
 Re: Case 2470 powershift seals (piston) in reply to Mike S 806/H, 07-31-2006 21:11:05
We just say the pistons are the newer style. I suppose everything rests on the attitude of the parts people at the counter. We keep the parts numbers in a binder, then just give them that when we order. If you do that, there can be no argument.
Grumpy
07-29-2006 20:03:34
The pistons are not the same. Do not use the old kit. Get the right one. Stan
430WLPG
07-29-2006 19:46:36
You have a old style kit,they were originally like that,I don't see why they wouldn't work,but the down side those are a pain to put in.
