Info. on 930 vs. 600 axles
SupC
07-29-2006 18:03:39
I have an old 6 speed,hand clutch, 930. I currently have 26 in. rear hubs and wanted to put Case 34 in. cast centers on, I got some from a 600, that I nver took the time to measure to see if they we're the same diameter, and the 600 hubs are around 1/4 in. smaller in diameter. My question is this . Did Case have an axle in a 900 or something else that would fit the axle bearings of a 930, but the taper on the outer end fit a 600 hub center? Also does anybody know if a 900 has the same diameter as the 600, or 930, or is it different than both of those. Thanks a lot,Willie
DKase
07-30-2006 10:22:45
 Re: Info. on 930 vs. 600 axles in reply to SupC, 07-29-2006 18:03:39
I have a parted out early 930. Someone that was looking for the same thing as you are told me that the axles and the taper was different, but you can make it work by changing the axle housings with the axles and wheels. Mine are 34", are for sale, and in Eastern SD. DK
SupC
07-30-2006 11:42:27
 Hey DKase in reply to DKase, 07-30-2006 10:22:45
What you ares saying is I should be able to swap axle,axle housing and hubs from a 600,900,etc. and the housing should fit by rearend housing. Is the bull sprocket the same between these teractors where it splines onto the axle or are they 2 different sizes? Thanks for the help,Willie
DKase
07-30-2006 17:40:47
 Re: Hey DKase in reply to SupC, 07-30-2006 11:42:27
I have never looked into the subject very far. I do not have the parts books to tell me if the part numbers are the same. The guy that was going to get the parts from me was going to get the sprockets and all. Someone else out there should have a solid answer. DK
SupC
07-30-2006 18:41:27
 Thanks DKase in reply to DKase, 07-30-2006 17:40:47
I have the part number for the 930 if anybody out there has part book for a 900 and 600 I'd appreciate the help. Thanks,Willie
Camboted
07-30-2006 04:21:47
I'm afraid I can't help you but, that is news to me. I always thought everything from the 930CK six speeds back to the LA's had the same axels.
