VC Governor
jags
07-28-2006 07:53:30
How do you adjust the Governor on a VC Case? I know the manual says that it is "Pre-set", but I would like to raise the governed speed by 300-400 rpms. This is the continental engine that I know was used in many other applications (such as fork lifts) that ran safely at higher RPMs (up to 1750). I would like to run this at about 1500 rpms.
Alberta Mike
07-29-2006 07:05:49
 Re: VC Governor in reply to jags, 07-28-2006 07:53:30
If you still have the factory throttle linkage assembly (which is a nightmare, whoever designed that setup), I think that going inside the "tube-within-a-tube" assembly and replacing the spring that's in there with a stronger spring would enable you to raise the RPH that the governor regulates. There doesn't seem to be any settings on the governor linkage itself if I remember correctly. Respond back if you will, thanks.
