Case 300 Hydraulic lifting
hobbyfarmerinWI
07-27-2006 19:55:52
According to the manual of my 1957 case 311, the Eagle Hitch and Hydraulic System has a Relief Valve Pressure rated at "1200 to 1300 psi".
Based on that, and the fact is is 49 yrs old, how much would you GUESS the 3 pt or loader would lift.
I am asking to decide if I can use it to move round bales in the 700-800 lb range.
Thanks
Triplerange
07-28-2006 13:10:49
 Re: Case 300 Hydraulic lifting in reply to hobbyfarmerinWI, 07-27-2006 19:55:52
We've moved big round bales with a 300 before. And we had the front end off the ground more than a handful of times. Be very careful.
Camboted
07-28-2006 04:10:10
If you can hold down the front end it should lift them. You may need to stick a 5/8 hut on top of the relief valve if the spring is worn.
