SC sleeves???
Camboted
07-26-2006 03:44:15
I know that most SC sleeves used one O ring and were smooth, the groove was in the block, right? But then in 1952-54 the tractors used the same exterior bore but the sleeve had two grooves for a double O-ring, is that correct? Question, will either of the sleeves work in both machines? ie) will the double groove sleeve still allow the single block grove o-ring to seal?? Or are both sleeves needed to provide re-build kits for SC's???
4435
07-28-2006 14:19:20
 Re: SC sleeves??? in reply to Camboted, 07-26-2006 03:44:15
Ted they aren't even close. The early model SC sleeves will nearly drop thru the bores in the late series block. Been there done that. Tom
wilson
07-26-2006 18:51:03
I dont thins they will seal However ed axeltherm Phone in old abes news has more sc experience than most. Ted e mail me about nebraska tractors Bill
dboll
07-26-2006 13:28:10
Don't the counter bores have differen't dimensions? Though they did.
