case vai hydro pump gear
Mike ( SC )
07-24-2006 16:27:51
I have a 49 vai that I am restoring. It has an engine mounted hydro pump. When I broke the motor down there was no shaft or gear on the pump so I am looking for a pump. The part book calls for 2 different drive gears a 7/8" or a 1 1/16" gear how do I tell which gear I need. It has distributor ignition. Thanks.
Jerry W
07-24-2006 19:59:49
 Re: case vai hydro pump gear in reply to Mike ( SC ), 07-24-2006 16:27:51
I believe that measurement is talking about the width of the gear. Early VAC Eagle Hitch tractors used a gear the same width as the magneto drive (7/8") but it was found to be a little weak so a wider gear was issued. I am not aware of any problems from using the later/wider gear on any of the pumps. I would look for the later gear.
Jerry
