CASE 530CK
H.W.Murphy
07-24-2006 16:24:21
I have what I think is a 63 530CK loader/backhoe. The power steering is not like in the manuals. It has a single cylinder operated off a standard looking manual box. The pump is integral with the 188 diesel and the reservoir is separate, just aft and below the glow plugs on the right side. Does anyone know what I have? I can send pictures but have no website to post as a url.
Roger (Mi)
07-25-2006 04:32:54
 Re: Case 530CK power steering in reply to H.W.Murphy, 07-24-2006 16:24:21
The power steering that you're describing is the early Bendix power steering unit. The steering box simply moves a valve on the power steering unit. While the valve can be rebuilt, the cylinder cannot. If a dealer cannot get parts, they're usually available from salvage yards. The same power steering unit was used on the agricultural models too.
H.W. Murphy
08-02-2006 06:01:58
 Re: Case 530CK power steering in reply to Roger (Mi), 07-25-2006 04:32:54
Roger, Thanks for the info, thought I had some wierd setup. I just have to get creative as George MD recommended.
george md
07-25-2006 18:04:59
Roger,
Put the cylinder in the lathe and cut the weld out carefully , take apart and repack ,
weld it back together . You do it like some of the older dump truck cylinders . I did mine many years ago , and it's about due
again .
george
