oil pump
johndeereman
07-23-2006 20:09:49
whats the quickest way to get to the oil pump on my 49 dc i think the screen is plugged . when working under a load i lose oil pressure i changed the oil when i first got it a couple of weeks ago and the filter was plugged solid
L.Lamp
07-24-2006 05:14:18
 Re: oil pump in reply to johndeereman, 07-23-2006 20:09:49
If it hasn't had the engine changed to a '51 '52, '53 or '54, the screen is easy to get to. There are three bolts at the bottom of the oil pan on the left side that hold on a round pressed steel plate. Remove them and pull the screen out and clean it. While you are at it clean the sludge out of the bottom of the pan too. Clean the plate and use black silicone rubber sealer and reinstall it. The later engines above had a floating intake without a screen.
