830 Eagle hitch
Roger H
07-22-2006 12:39:11
I recently bought a Buhler finishing mower & put it on the 830, however , as I suspected, it won't lift the way most 3 points do with the top link in the high position on the tractor, all it does is pick up the front of the mower & the rear stays on the ground, has anyone else ran into this problem & what did you do about it? I'm thinking about getting a hyd. cylinder & use it as the top link, any other ideas? Thanks
Gene Dotson
07-23-2006 02:37:34
 Re: 830 Eagle hitch in reply to Roger H, 07-22-2006 12:39:11
The solution is simpler than the hydraulic cylinder. You need to raise the top link point on the mower. I think I raised mine by about 13 inches. I used 2" by 3/8" flat iron and welded it to the top of the top link on the mower. I drilled several matching 3/4" holes holes in the straps before I welded them on to have a selection of holes to use... Gene
