580CK hyd problem
07-22-2006 08:07:51
When I operate the loader up or down, binding accrues. The binding get worse the longer I operate, also after operate for a long time. I can't lower the loader arms when the machine is not running. Its seems to need hyd pressure. The front bucket and the backhoe run smoothly and have plenty of power. Both loader cylinders were rebuild 3 years ago.
I'm thinking I have a bad seal in one of the cyl and as it heats up, the barrel expands and the hyd fluid is leaks by.
Phil (NJ,AZ,Sask)
07-26-2006 15:54:31
 Re: 580CK hyd problem in reply to [email protected], 07-22-2006 08:07:51
Bronner, I have a 530CK and had a problem with leak-by in the FEL control valves... I could remove the large cup/cap on the rear of the control lever assy (tractor front) and drain the fluid build up and she was good for go again. It was only a problem after working the FEL hard & long.
Hope this helps,
