Case 440 Compression
CK from Ontario
07-18-2006 17:13:13
I have a 440 that I tested the compression on and all cylinders are 130 psi, give or take 5 psi. Is this a normal reading?
CK from Ontario
07-19-2006 20:13:39
 Re: Case 440 Compression in reply to CK from Ontario, 07-18-2006 17:13:13
Thanks for the help Tom, it is a more recent machine, and so possibly in better shape/better built.
Tom (Ks)
07-18-2006 18:37:50
Spec is 115 psi on a 430 gas, sounds like you are pretty good there.
CK in Ontario
07-19-2006 05:59:32
 Re: Case 440 Compression in reply to Tom (Ks), 07-18-2006 18:37:50
Thanks Tom, I guess the increase in compression could be caused by carbon buildup?
Tom (Ks)
07-19-2006 16:44:25
 Re: Case 440 Compression in reply to CK in Ontario, 07-19-2006 05:59:32
No, some engines were just better than others. Case used that number as a base line. You are good as long as they are real close on pressure, all around 115 or all around 130 or whatever you run across.
