Casomatic Help
Newcaseguy
07-18-2006 05:42:18
I recently purchased a Case 811B Case-O-Matic tractor. It feels like the clutch is slipping. I know it does not have a clutch, but thats what it feels like. Is that normal? I don't know anything about the case-o-matics. It also has a small lever to the left of the steering wheel that acts like a TA on an IH and gives you another gear, that feels fine (is this on all case-o-matics?). I don't know what oil to use, is the oil the culpret, or is it something bigger? Help!!!!
Jim in Calf
07-18-2006 08:53:41
 Re: Casomatic Help in reply to Newcaseguy, 07-18-2006 05:42:18
Just think you are driving a standard eight-gear transmission with a torque converter. Once you get the tractor moving, you can put it into "Direct Drive"(the little lever on the left side of column). Direct drive is like a �locking� torque converter in an automobile. However, you control when your "Converter" is "locked" not a computer.
dctom
07-18-2006 06:03:50
no problem, it will always start out in case-o-matic thru the tourque converter, little lever locks in to direct drive, case ch or hy-tran is ok fluid
dctom
07-18-2006 06:03:55
