Case David Brown 885...
BCnT
07-17-2006 19:47:34
howdy yall...new david brown owner here...just bought what i believe to be a 1971 CDB 885...runs and drives great but someone evidently removed a valve and rear remotes and left the 2 ports on top beside the 3 point control open...auction company i got it from stuck a couple spark plugs in ports to stop fluid from spraying out...anyhow the 3 point goes up when tractor starts but wont hold any weight at all and when you shut tractor down the 3 point immediately starts falling...do i just need a hose loop to get flow into controls or is something else messed up? also what type fittings does the port take? local indy tractor dealer barely knows how to spell ford so i cant get much info from them.
thanx
chuck
RPoff
07-18-2006 12:17:26
 Re: Case David Brown 885... in reply to BCnT, 07-17-2006 19:47:34
You should change the fluid and the filter. Also, you have the manifold there it sounds like. Why not add a remote? You could put a 70 dollar northern tool open center valve and have a cylinder remote. Great for hyd. toplink.
BCnT
07-18-2006 15:24:49
 Re: Case David Brown 885... in reply to RPoff, 07-18-2006 12:17:26
rite now i just want to make sure the hydraulics work...i've got a 3 spool to go on later.
where is this filter you mentioned? i've looked high n low for it.
richard in nz
07-18-2006 03:44:05
Thre should be a cast plate with some passages in it and a couple of 7/8 UNF threaded ports bolted on where the remote valve has been removed.
BCnT
07-18-2006 05:53:02
 Re: Case David Brown 885... in reply to richard in nz, 07-18-2006 03:44:05
theres a cast plate on top with twin raised ports...think i'm gonna pull it off and take to town with me and have a hose made.
thanx for help
