Case Question
Logan in S.E. T
07-17-2006 08:22:07
My neighbor just purchased a 1987 model 1494 (?) Case 4 wd with a David Brown engine. I have yet to hear it run, but he says it sounds good, it has electrical issues with starter / alternator that he is working on. It also has leaks on both hydraulic pumps in the front, but he says he found rebuild kits on line for them for $45/each.
I have no experience with Case products, I would like to here others thoughts, comments, experiences with these tractors. Any helpful tips would also be greatly appreciated as neighbor is a self-admitted "city-boy" that has just moved to the country and doesn't know anything....Thanks.
richard in nz
07-17-2006 16:51:44
 Re: Case Question in reply to Logan in S.E. Texas, 07-17-2006 08:22:07
The tractor is all David Brown, by the time it was built the engine had got as much power as could be got from what is basicly a 1930s design. It still has a 3 main bearing crank shaft and bottom end troubles are not uncommon on tractors that have been given a lot of hard work. The back end and gearbox were all beefed up and oil immersed disc brakes fitted to cope with the extra power and wieght. Its replacement which I think was going to be called the 1496 used the CDC (Cummins) engine in the prototypes but never saw production due to David Brown Tractors parent company - Case and the International harvester company merging in 1985. The 1494 was dropped although there were some red ones produced untill (as far as I can remember) there were only 1394 and 1594 tractors being sold just before the plant was closed in 1988. For serious hard work the 1490/94/10 and 12 tractors I would not recommend, how ever on a lifestyle block doing moderate work it should be as good as anything else of comparable performance and age.
