2290 inching pedal
J Bob
07-16-2006 19:41:00
I have a 2290 powershift that when it warms up does not allow one to ease the clutch out. It seems to be all or nothing. Lately it has started to not want to shift into 2nd gear, the engine labors tremendously until you push it up to 3rd and then it is ok. I also have a 2090 that works fine, I switched control boxes to try to locate the problem but the problem stayed with the 2290. Any thoughts on a cure? Thanks, John.
Grumpy
07-17-2006 05:21:58
 Re: 2290 inching pedal in reply to J Bob, 07-16-2006 19:41:00
If you switched the control valve and the problem stayed with the 2290 then your problem is internal. The tractor will have to be split at the motor to get to the powershift. You have a problem in the C2 clutch. I would guess that the piston is stuck. Stan
J Bob
07-17-2006 19:20:50
 Re: 2290 inching pedal in reply to Grumpy, 07-17-2006 05:21:58
Thanks for the info. This tractor was split earlier for shifting problems/ thought they had it . Is there any possibility of some sort of flow divider not working right. The steering also wants to act up sometimes when ideling.
430WLPG
07-16-2006 19:51:45
There's a modulating dart, spring and a special washer in the bottom of the clutch control spool remove the plug on underneath the clutch spool and check these parts,usually the washer and spring are broken.
