hydraulics
johndeereman
07-16-2006 15:42:58
49 dc where is the hyd. reservoir does it use the tranny fluid for hyd. if so can you use tranny /hydraulic fluid in it i can get that a little cheaper than 30weight also looks like a filter housing on the side of the hydraulic pump im new to working on case all help is greatly appreciated.
dctom
07-16-2006 15:52:20
 Re: hydraulics in reply to johndeereman, 07-16-2006 15:42:58
JD man, there are two plugs on top left of the hydralic unit the big one goes to the rear end and the smaller one is for the hydralic pump. it dose use 30 weight oil, the newer oil is a little thin for use in thoes old pumps, yes that you see is a filter that can be bought new from your friendly caseih dealer lol tom
