case vac - adding a 3 pt?
city boy with a
07-13-2006 20:02:55
I just bought a vac with only a drawbar and am wondering if I can add a three pt to it? And if the three pt off a vac-14 would work?
mj
07-15-2006 16:43:09
 Re: case vac - adding a 3 pt? in reply to city boy with a tractor, 07-13-2006 20:02:55
third party image
Here's one using an Allis WD rockshaft. Click the link for more then click a photo to enlarge.
Dave Stringer
07-17-2006 10:52:49
 Re: case vac - adding a 3 pt? in reply to mj, 07-15-2006 16:43:09
That looks like something I could handle. Where did you find that 3 point assembly? Did you have to do any welding or does the whole thing bolt on with a little modification?
Gary Cash
07-13-2006 23:34:18
I added a picture of my "1945 Case WF" to the Tractor Photos file in the Galleries. The photo shows my very old after-market 3 pt hitch.
1031D
07-13-2006 20:50:37
The VAC-14 eagle hitch will only work if you swap the rear end housing and add the live hydraulic pump unless you have a rear end with 4 mounting holes in 2 ribs on top. Case made a "kit" for putting 3 point hitch on an older VAC, and it basically was made up of axle bracket and lift arms, a welded rockshaft that raised and lowered off of the belly lift. They work. I have a parts manual for one of these kits, and if your handy with a welder, it should only be a weekend project.
