Case DB 990 Clutch Problem
Steve Dailey
07-13-2006 10:52:53
My tractor worked fine the last time I used it. Yesterday, when I attempted to put it in reverse to back it out of the barn, the gears ground. I had about 1/2 inch adjustment left on the adjusting rod, so I adjusted the clutch, but it did not make any difference. I have not tried the PTO yet. Any suggestions on what my problem is and what I need to do. Thanks!
jonjon
07-13-2006 13:38:45
 Re: Case DB 990 Clutch Problem in reply to Steve Dailey, 07-13-2006 10:52:53
clutch could have frozen or rusted.
Steve Dailey
07-13-2006 14:12:25
 Re: Case DB 990 Clutch Problem in reply to jonjon, 07-13-2006 13:38:45
Thank you. It has only been about a month or so since I last used it. It would be odd if it froze up. In case it is froze up, any suggestions on how best to free it? Thanks!
BCnT
07-17-2006 20:38:36
 Re: Case DB 990 Clutch Problem in reply to Steve Dailey, 07-13-2006 14:12:25
not odd at all to have a clutch stick like that...i got a 62 ford 2000 that i been running since new...ut'll stick if humidity gets high for a week or so...i generally run a remote starter switch and start tractor in gear and then drive around mashing and releasing pedal...doesnt take too long to break free...make sure youre pointed in a safe direction and ready to drive if you try this!
Stephen Dailey
07-19-2006 09:04:42
 Re: Case DB 990 Clutch Problem in reply to BCnT, 07-17-2006 20:38:36
Good News!
I got the clutch freed up last evening. All I did was hit the clutch several times hard (while the engine was off), then started the tractor -- and it shifted just fine. What a relief! Thanks for your suggestion.
Stephen Dailey
07-18-2006 07:13:20
Thanks, BCnT.
I'll give it a try tonight.
