Help O-Rings for Eagle lift
paul
11-15-1999 05:21:33
I have a 630 that has a piston from a 400 in the
lift. I went to the case dealer for new o-rings
they got a kit with 2 steel rings and 1 large o-ring. The problem is how should the rings be installed. The piston has 3 slots top slot is narrow and 2 larger at the bottom. The lift was disassembled when i got the tractor and the rings were gone. One steel ring will fit in the narrow slot and the rubber o-ring fits the larger slot.
Should there be 2 rubber o-rings????
Larry
11-16-1999 09:04:32
 Re: Help O-Rings for Eagle lift in reply to paul, 11-15-1999 05:21:33
Sorry I didn't get to you sooner.The way it looks in my repair book you need,1 piston o-ring,1 cylindar head o-ring 1 piston rod o-ring,1 piston rod oil seal,1 piston rod gasket. The only steel ring I see would be a snap ring that holds the cylindar head in place.Getting something that is disasembled when you get it can be a real pain.If all the parts don't seem to match up you will be better off finding another cylindar that would be right for you tractor. Good Luck : )
