VC clutch shaft
Wideload
07-13-2006 06:45:29
I need a new VC clutch shaft (the shaft that runs from the clutch disc to input shaft of transmission). Have heard that the VAC model uses the same clutch shaft could someone confirm it? Or tell me where to get this clutch shaft.
Alberta Mike
07-14-2006 15:37:29
 Re: VC clutch shaft in reply to Wideload, 07-13-2006 06:45:29
I'll confirm it, the clutch shaft from a VA will work. I used the clutch shaft from a VA (standard wide front) on my V (standard wide front) and they are identical. I used the old one as a pilot shaft when I installed the clutch assembly to the flywheel.
