What is known about factory LPG SC's?
jal-SD
07-13-2006 06:43:25
Does anyone know if Case made any factory LPG SC's? I don't remember seeing anything about LPG SC's in the stuff I've read, but I don't have "Full Steam Ahead" either. I think what I saw out in the weeds yesterday was an LPG SC. It looked factory. I didn't have time to stop, but I'm going that way again next week & know where to stop and plan to take a good look. Thanks in advance for any info that you might have. (My $0.02 worth. jal-SD)
Barry Small
07-15-2006 09:07:36
 Re: What is known about factory LPG SC's? in reply to jal-SD, 07-13-2006 06:43:25
My 49 LA was a gas tractor that was converted to LP in 1960. You wouldn't know it wasn't a factory setup looking at it though. It is factory smooth, but I've never seen another configured like it around here, or in books.
dboll
07-14-2006 11:00:49
got the head about figured out,don't want to say too much until I know it will work , plan on using pencil tip injectors with cup pistons and a Bosch or Roosa pump, I saw a B JD converted to dsl. at the JD expo once and I thought it was really neat!
jal-SD
07-14-2006 05:40:45
Thanks guys, for the info. I'm sure it was an SC, as it did not look like a cast iron grill-thats what caught my eye-I'll take a close (walk up to it) look next time I get out that way. (Another $0.02 worth. jal-SD)
dboll
07-14-2006 05:06:25
SC engine
1031D
07-13-2006 20:54:34
I live in southeastern wisconsin, and we had a local gas company that did conversions for many of us in the 60's. My neighbor had a McCormick W-9LP, and it looked factory! I have a VAC LP that they did for me, and I still use it. The "SC" you saw could be a DC LP, which they did make, as I know my DC and SC look alike parked in the weeds.
dctom
07-13-2006 15:40:03
Never was one, farmers can make anything look good
dboll
07-13-2006 09:18:23
Case never made one that I am aware of. Some of the aftermarket conversions were very nicely made. I thought of making on but am concentrating on making an SC diesel instead.
BobKY
07-14-2006 06:40:48
 Re: What is known about factory LPG SC's? in reply to dboll, 07-13-2006 09:18:23
dboll- I am very interested in your conversion. I have thought of trying it with a little briggs and stratton just to see if it could be done (not that I would expect that a splash lubed lawnmower engine would last very long). I figured that I could shave the head and experimentally use a vane type power steering pump for the injection pump (relief valve will max at about 1200 psi) but I still had not figured out a way to time/meter the amount of diesel injected.
What is your plan for increasing compression to 22/1? What types of injectors/pump will you use?
Lamont
07-13-2006 10:05:33
What engine are you going to use?
