Case 580B
Terry Healy
07-12-2006 14:53:29
I have a case 580Bck (year about 1972). I have developed a loud metalic knock in the engine and it smokes quite a bit (whitish smoke). It still starts right up but the noise has me worried. Firstly...does anyone have any idea wht it could be (bearings etc) and secondly if nesessary can I just pull the head, drop the pan and push the cylynders out to check for trouble whith the engine while in the frame...I am worried about having to split it. It is just for farm use so obviously the cheapest solution would be the best for me.
Thanks, Terry ....Ontario, Canada
Terry Healy
07-15-2006 19:00:47
 Re: Case 580B in reply to Terry Healy, 07-12-2006 14:53:29
I have removed the engine today, and find that I have what looks like a jelly type of substance under the valve cover, could that be water and oil mixed? If it is is it from the frost plugs leaking or a cracked head? Also the # 4 cylynder is very wet with fuel (not firing?) and I suspect will show a problem when I drop the pan. I also noted when I removed the engin a small pin in the upper left corner (looking into the bell housing)of the casting inside where the torque converter is located. It seems to have no purpose....is it perhaps to aid in alignment of the two ring gears? Anyway...will try to pull head and drop pan tomorrow, but am thinking of looking for a good used serviceable engine. If someone had one near Toronto, Canada please let me know and also what you would want for it, thanks, Terry
Roger (Mi)
07-12-2006 18:29:09
 Re: Case 580B with engine noise in reply to Terry Healy, 07-12-2006 14:53:29
Anytime an engine is making a noise out of the ordinary, it's a cause for concern. You can check the problem by pulling the pan. There is no need to split the tractor at this time. I would be surprised if your problem is simple. Check the connecting rods. It's likely that you have at least one defective connecting rod bearing and a damaged crankshaft, then you will need to split the tractor to repair the engine. Good luck.
Terry Healy
07-12-2006 19:19:00
 Re: Case 580B with engine noise in reply to Roger (Mi), 07-12-2006 18:29:09
Roger, Thanks for the quick reply. I will start to by taking off the head and checking the pistons for travel to see if a rod is bent and also drop the pan and check the rod bearings. Hopefull It will only be a rod or rod bearing and not the crank itself. Should I replace all rod bearings, rings etc. if that is the cause or just the one(s) causing the problem. I take it the only way to get the crank itself out is to split the tractor ( a dangerous job?)
Regards, Terry
Roger (Mi)
07-13-2006 03:37:25
 Re: No easy fix if a rod bearing is bad in reply to Terry Healy, 07-12-2006 19:19:00
Terry,
Gone are the days when one can simply shim a connecting rod or make do with a bad crankshaft. Modern high speed engines will not allow it. Your engine has tolerances of thousandths of an inch (.0015) between the rod bearings and the crankshaft journals. The same is true for the main crankshaft journals and bearings. If a rod bearing has spun, that connecting rod will need to be reconditioned or replaced. In the above situation, the crankshaft can only be removed by splitting the tractor. Removing the engine is not dangerous. Just use some common sense. Engine lifts can be rented, if you don't have one. There is a saying: If you don't have time to do it right, when will you find the time to do it all over again. Any problems, give me a shout. Again, good luck.
