Case 530 Construction King PTO
aksport
07-11-2006 20:29:02
I'm looking at a 530 CK with, 3-point but NO PTO. What would be involved in adding the PTO? It has a flat cover plate over the PTO position. Can the PTO parts just be added in?
Thanks
Roger (Mi)
07-12-2006 03:32:49
 Re: Does Case 530 CK have COM? in reply to aksport, 07-11-2006 20:29:02
If the 530 has a Case-O-Matic drive, an independent PTO can be added without much problem. I believe a regular PTO can added to a standard clutch 530 CK with a shuttle, but the shuttle is taking the place of the hand clutch. The hand clutch on agricultural models is used to stop foward motion while the PTO can continue to run. In other words, when you push down on the clutch pedal, both forward motion and the PTO will stop.
