O.T. Question on Minn. Moline M670 Carbueration
C.D. Zook
07-11-2006 11:55:27
Hello,
I am trying to help neighbor with his m670. Has sat for couple years. Cleaned carb. new needle & seat, gaskets etc. and have gas flow. Tractor has fire at plugs & can observe black smoke out exhaust,when turning over engine, but does not attempt to hit or sputter and have choked heavily, but can not get sign of gas on plugs when removed after choking & turning engine over for couple minutes. Any suggestions?? Also need Firing Order for engine. Thank You,
C.D.Z.
Walt Davies
07-12-2006 08:18:02
 Re: O.T. Question on Minn. Moline M670 Carbueratio in reply to C.D. Zook, 07-11-2006 11:55:27
sounds like low compression do test to check it out.
Walt
Also you might want to run this though the MM forum where they have more knowledge of the tractor.
