830 low on HP
GeoM0
07-11-2006 07:53:41
My sons and I overhauled my 830 diesel a year ago. Someone had interchanged # 3 and # 4 rods before I got the tractor. I do not know how it ever run or held together.
We had the block redone, top planed and inserts made for sleeve O-ring.
We had the head redone and the injectors checked.
It starts easy and sounds good. It does real well on fuel. I mowed (sickle mower) 6 hours on approx 5 gallon and baled 8 hours on 10-12 gallons.
On flat I can bale in L4 but when I get to a hill I sometimes have to go to low.
Thank You for any help, my dealer is a converted IH dealer.
c hess
07-11-2006 19:40:42
 Re: 830 low on HP in reply to GeoM0, 07-11-2006 07:53:41
Dont know enough about tractor such as does it have fuel pressure gage an what is pressure - does it smoke when pulling at full throttle-It should smoke somewhat. I dont know what baler you may have but if a small square baler it should not ever run out of power. Check timing as Jim said an make sure T handle is turned in on top of fuel filters if yours has one. Idont think all had same filter as mine. Also what is high idle speed of tractor.
GeoM0
07-12-2006 04:52:38
 Re: 830 low on HP in reply to c hess, 07-11-2006 19:40:42
Thanks guys.
We set the timing by book same as before but I will check and play with.
I baled with a square baler last year, this year I am baling with a vemeer big round baler.
jim in calif
07-11-2006 10:02:31
Check your injection pump timing. Only 1 degree off will make a big difference.
