VAI Serial # vs Model year?? Dist vs Mag
Paulf
07-11-2006 06:20:12
1. A friend recently got a VAI Serial # 5750169 now I know that should be a 1953. Thie one was sold to teh Department of the Navy. She still has her brass Navy data plates. They show teh serial numbe but date of manufacture is stamped 1952. Did Case use a model year like automobiles vs calendar year???
2. VAI came with a mag ...now missing. There is a plug in the side of the block for the distributor. Question is there the necessary gear in there to drive a distributor??? Getting a distributor would be cheaper than getting a working Case Mag and also easier to find parts for later on.
Thank you
Artie Zabel
07-12-2006 16:48:26
 Re: VAI Serial # vs Model year?? Dist vs Mag in reply to Paulf, 07-11-2006 06:20:12
Just a heads up. I posted a complete original VAI parts catalog it's free to view and download
on my website http://www.antiquefarming.com
Gene Dotson
07-11-2006 19:00:09
Paul.
Most flange mount mags will work on the VA engines. A Fairbanks-Morse will work fine and parts are available for them,
For the distributor, the drive gear is part of the camshaft and is the same as the mag camshaft. There should be a 1/4 X24 hole drilled and tapped for the hold down bracket on the distributor. Distributor is the same for all 124 and 148 engines. With a distributor, you will have to find a blockoff plate for the magneto drive opening... Gene
Paul f
07-12-2006 08:21:46
 Re: VAI Serial # vs Model year?? Dist vs Mag in reply to Gene Dotson, 07-11-2006 19:00:09
Gene: Thanks for the info.
dctom
07-11-2006 07:22:31
No they could have bought it in late 52 and thought that was year of manufacture which could be right cause case used oct 1 as fiscal year start still a 53 model
Paul f
07-11-2006 07:26:23
 Re: VAI Serial # vs Model year?? Dist vs Mag in reply to dctom, 07-11-2006 07:22:31
Thank you Tom
