730 PTO replacement
LA4farmin
07-10-2006 18:26:42
I have a 734 with a broken PTO shaft. When attempting to remove the shaft, the fork that engages the clutch is in the way of the removal of the clutch/shaft. The hydraulic unit sits above the PTO. Do I need to remove the hydraulic unit in order to get the fork out of the way? Any details would be helpful. Thanks...
scman
07-11-2006 06:19:11
 Re: 730 PTO replacement in reply to LA4farmin, 07-10-2006 18:26:42
Yes, remove the hydraulic pump. You have already drained the fluid, and it is only four bolts. Once you have removed the pump you will be able to take out a bolt that holds the shifting fork onto the shaft. Remove this bolt then pull the shaft, this will require you to remove the pto linkage. the fork is keyed to the shaft so watch to make sure you don't lose them. The pto should be free and ready to pull after this. good luck
James Heitkemper
07-11-2006 20:32:27
 Re: 730 PTO replacement and 54,SC in reply to scman, 07-11-2006 06:19:11
Can you help me with knowledge of a SC Case ...Simply Can I bolt all the 1954 SC parts into and onto a 1944 SC transmission housing ?...All things such as Foot clutch ,Live power and hydraulics ,and1954 brakes? I have the donor tractorshere to accomplish this if I knew it could be done ..
DKase
07-10-2006 20:34:12
Been some time since I have had one out. Take the small cover off the top? and loosten the bolts in the fork, and remove the shaft that goes through the fork. Remove the fork, and remove the PTO. DK
