Fuel Filter
inCASEyougetstuck
07-10-2006 16:12:09
My case will act up..I cleaned out the gas tank,diddnt help.checced fuel hose,And carbuerator..I dont know.The only thing i know is that is does not have a fuel filter.
C. Amick
07-12-2006 10:02:17
 Re: Fuel Filter in reply to inCASEyougetstuck, 07-10-2006 16:12:09
If you think it is a dirt problem, I would install an in-line filter. NAPA sells the plastic ones that you can see through. You just cut a section out of your fuel line and clamp them in place, using the hoses and clamps that come with them. I would also suggest you buy a plastic fuel cut-off valve (ball valve) to install in-line just upstream of the filter. NAPA has those as well.
