VAC Distributor
JustIn Case
07-10-2006 13:26:07
Has anyone re-bushed a distributor for a VAC? The guy at the local Generator/Starter shop said he didn"t regularly work on distributors but he"d probably make me a bushing. Should we try to find/use oil impregnated bushing material or just brass? What kind of shaft to bushing clearance should we shoot for? How hard will the old bushings be to get out? 1946 VAC currently has and I plan on keeping grease cup on distributor, what grease is recommended. Tractor currently runs but distributor is worn to where setting points is quite difficult. Would I be best off purchasing a Pertronix electronic ignition? Any viewpoints on this would be appreciated
Joe (Wa)
07-10-2006 16:12:56
 Re: VAC Distributor in reply to JustIn Case, 07-10-2006 13:26:07
If your distributor is Auto-Lite p/n IAD-6000 - 2F (or 2J) the bushings are Auto-Lite p/n IG-579A. 2 bushings are req'd and you may have to drill a grease hole in the top bushing.
I bought these bushings from Case and the Case p/n may be A24766. But check that p/n with a Case dealer if going that route. I bought several different bushings from Case during that time frame and the nomenclature for all of them is just "bushing" on the invoices so I am not sure about the p/n.
Joe
