LA Weekend Workout
Gene Dotson
07-09-2006 19:57:39
This past weekend I attended the Greenville, Ohio antique tractor show. I took my 1948 Case LA to run the 1955 Frick sawmill. This is an annual event for me.
I rebuilt the engine during the winter with 4 7/8" pistons and sleeves and installed a 5845A propane head. What a difference this has made in the power of the tractor. I estimate to be about 85 horsepower now and was able to run the saw even in the heaviest of cuts very well. Most of the logs were red oak, so it wasn"t easy sawing at all.
I belted up to the mill on Thursday with about 1 hour total running time since the rebuild. Ran about 4 hours on Thursday, 6 1/2 hours Friday, 6 hours on Saturday and finished out with 3 hours on Sunday. Burned over 55 gallons of gasoline and used no oil or water. The club furnished the gasoline that was donated by the local oil distributor.
My new 1200 degree paint job on the exhaust stack didn"t even make it through the first cut, gone up in smoke. It was the perfect job to break in the engine
The sawyers on the mill were very impressed with the tractor and want it back next year... Gene
C. Amick
07-14-2006 09:20:00
 Re: LA Weekend Workout in reply to Gene Dotson, 07-09-2006 19:57:39
It calculates to burning around 3 gallons/hour which is a lot better than I would expect for an LA under a load. It seems like a DC would burn that much under a load?
AllanC
07-10-2006 21:05:59
I gave my LA a good run last weekend too, seeded 30 acres of oats for fall grazing. There's a pic posted on the tractorshed. It has the big pistons but regular head and used less fuel than I expected. Not that the drill is a big load.
Walt Davies
07-10-2006 12:59:00
Gene, Nice show we need to let those ugly green things what real power is when you need it, Giggle.
I have the LP pistons also they give it a little bit more compression as they go up into the head about and 1/8 of an in. Walt
Dutchman
07-09-2006 20:13:16
Sounds like you had a GREAT time !! did you take any pictures ?? LOVE to SEE them... MV
Gene Dotson
07-10-2006 20:09:06
 Re: LA Weekend Workout in reply to Dutchman, 07-09-2006 20:13:16
Sorry, guys. I didn"t get any pictures. The camera was in the camper, but I didn"t even have it out.
It was a great time with the tractor, but it was really getting tiring by the time we finished. Would have liked to spend more time with the rest of the show... Gene
Steve-MN
07-09-2006 20:09:09
Gene,
Sounds very impressive. Would have liked to see that! Good fun.
Wonder what temp that manifold gets up to. I remember mine(Dad's) in the 60's & 70's when it got dark. The entire stack & pipe was cherry & the flames were coming out the top. (tad rich maybe?:)
Steve
Gene Dotson
07-10-2006 20:17:40
 Re: LA Weekend Workout in reply to Steve-MN, 07-09-2006 20:09:09
Steve;
A lean mixture runs hotter than a rich mixture and an engine running in cold dense air will run hotter than running in hot les dense air. My airplane will typically run at about 1425 degrees in the winter and about 1390 in summer air running at best powerleaned mixture.
I would guess the LA was running at about 1450 degrees. On the long hard cuts, the stack was glowing red, even with the bright sun... Gene
AllanC
07-10-2006 21:11:42
 Re: LA Weekend Workout in reply to Gene Dotson, 07-10-2006 20:17:40
Interesting what you say about your airplane temps. I never noticed that, but my old 170 only had an analog egt. My son has one now with digital runs around 1250 max. we'll see in the winter. What plane do you have?
Gene Dotson
07-11-2006 12:43:35
 Re: LA Weekend Workout in reply to AllanC, 07-10-2006 21:11:42
Allan;
I have a 1977 Maule M5 with 210 hp Continental... Gene
