Case SC generator
mpriar
07-09-2006 17:15:15
Guys, I want to convert my SC to 12v, but I want to keep the original look. What later model Case"s used 12v, or what other tractors used autolite generators?
Thanks
mpriar
Walt Davies
07-10-2006 12:54:46
 Re: Case SC generator in reply to mpriar, 07-09-2006 17:15:15
Get a late 50s or early 60s Chey truck Generator by Delco Remy they match right up and bolt right in. Cost next to nothing at your local parts house.
They are actualy the same generator as the early case 6 volt. Walt
amo
07-09-2006 17:42:29
a mechanic told me you can have 12 volt parts putin the 6 volt generator by a generator repair shop, keep the same starter and get a 12 volt battery and it will work and you will have same looks as original except the battery. good luck
PD
07-09-2006 19:18:02
 Re: Case SC generator in reply to amo, 07-09-2006 17:42:29
Sure can. I just got done doing it to my Ferguson TO-20. I had both the starter and generator rewound to 12 volts. Delco components are really easy to do. I installed an Ignitor while I was at it. What a difference in starting and the way it runs. Starter cost 85 dollars to have rewound and rebuilt with everything but the case new. Generator was 90 dollars completely redone. Ignitor was 95 dollars. Genuine Delco voltage regulator was 35 dollars. I would still like to replace the wiring harness, as mine has been repaired several times. Good luck..... ...P
