CIH 2096
Hayman
07-09-2006 07:46:13
Does anyone have experience with these tractors?
Are the powershifts anymore "robust" then the old ones like 2090's etc.??
I run an old 2090 and it works fine but we've had it since new and I know that the PS hasn't been abused over the years. Plus more then half it's life it's just baled hay so easy work for the trans. etc. I know the old Case power shifts can cost a pile of money to fix if you start taking out gears, shafts, and planetaries!!!
Looked at a couple of these 2096's and was wondering how they stack up. Would be used for 25% tillage pulling work and the rest hay mowing and baling.
Also did they come with an air ride seat??
John Saeli
07-09-2006 09:09:27
 Re: CIH 2096 in reply to Hayman, 07-09-2006 07:46:13
We have a 2096 that does plowing & planting among other chores. Power Shift on the 2096 uses electric solenoids that the 2090 didn't. Basically, it's the same RPS 34 Unit. I was told that some units had a Case 6 Speed P/S, but I have never seen one.
The Cummins engine is great. Lots of Torque, & a fuel miser. Have no idea where that 360 cu in gets it's power & torque.
Hyd. Seat.
We've had no trouble with our 2096. Great tractor.
hunit
07-09-2006 07:54:57
im pretty sure the seat is hyd. ours doesnt work any more not real good any way have had to repair a few things on it too over the years...
hunit
07-09-2006 07:53:03
we have an 1896 and it seems to work good do a lot of tillage work with it and bale too sure stuff wears out but for the most part it is good havent had to replace any gears just electrical stuff wich can get expensive...
