Case 930 long nose vs 930CK six speed
Camboted
07-09-2006 04:28:44
Does anyone know if the rear gear case (differential and transmission) from a long nose will work on a CK six speed? I know the shift cover is different, but is the rear casting the same? I have a CK with a cracked gear housing. Thanks!
1200TK
07-09-2006 14:28:57
 Re: Case 930 long nose vs 930CK six speed in reply to Camboted, 07-09-2006 04:28:44
Hello Camboted,
Yes the 6 speed long nose transmission and back end will bolt straight up to a Comfort King or visa versa. The trans is exactly the same, the only difference is the gear lever set up.
WONDERFUL TRACTORS !!!
I have owned two '930's", a long nose, Serial No 8165387, and a Comfort King Serial No 8250405, I still currently have the long nose.
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND
Lamont
07-09-2006 12:27:26
I think the following rules apply. "All 6-speeds interchange. All 8-speeds interchange. No swapping 6 to 8 or 8 to 6." Maybe someone else can clear this up 100%. I guess that wasn"t much help.
