530 pto
Rob Baird
07-08-2006 20:08:43
HI I have a 530ck with standard pto. I have found a live pto. Will that just unbolt and interchange or is it a major project?? thanks Rob Baird
Rob Baird
07-09-2006 05:17:48
 Re: 530 pto in reply to Rob Baird, 07-08-2006 20:08:43
HI Thank you I had found the live pto unit but did not know what all was involved. You have talked me out of that project. I did not think I would be luck enough to have it just bolt in. thanks Rob Baird
Roger (Mi)
07-09-2006 05:07:39
 Re: Change to independent PTO? $$$$$ in reply to Rob Baird, 07-08-2006 20:08:43
That would be a major project, if it can be done. The independent PTO has a long shaft that gets its power directly from the flywheel/crankshaft. The 530 does not. Its power comes through the foot clutch. The late model 530/570's had independent PTO's. Perhaps parts from those late model tractors could be installed into the 530CK? The tractor would have to be split. The clutch, pressure plate, torque tube input shaft, PTO shaft would all need to be changed. If you have to buy the parts new, you could nearly buy another tractor for cost of the parts.
