case 411 b clutch
roland withersp
07-08-2006 18:49:52
I have very little clutch what do I do, I understand it is different than most clutches. Help
Grumpy
07-10-2006 03:57:01
 Re: case 411 b clutch in reply to roland witherspoon, 07-08-2006 18:49:52
411B is a casomatic. There is no clutch. The pedal moves a spool in the control valve. There is a convertor just like a automatic trans in your car. Put the 4 speed in gear at a slow idle. Drop the clutch yes drop the clutch you cannot slip the clutch. Now speed engine up till you are moving easily let off the gas shift into direct drive and give her heck. Stan
John Saeli
07-09-2006 09:15:33
Case-O-Matic correct? Never saw a 411B with anything but. How long have you had the tractor, & what are the symptoms?
Roger (Mi)
07-09-2006 05:27:45
 Re: Foot clutch is not much different in reply to roland witherspoon, 07-08-2006 18:49:52
The foot clutch is not that much different than most other clutches. There is an additional spline on the pressure plate to drive the hydraulic pump to permit constant hydraulics. The original throw-out fork on these tractors and early 30 series tractors had a tendency to break. They're stamped metal. An improved fork was introduced in the mid-sixties. The improved fork has a paint mark. If you need to split the tractor for a clutch problem and yours does not have a paint mark on it, replace it. If you only lost foot pedal travel, adjust the linkage until there is 1" of free travel. Good luck.
