Case serial # VO4522891
Glenn Norwood
07-07-2006 13:11:25
I recently became the new owner of a Case tractor serial # VO4522891. It has Orchard fenders. It also has VT56 stamped on various parts. The old owner thought it was a 1949/1950. I did a serial # search and I think it is a 41 D. Any help out there. Thanks Glen in southern California 714 264 8709
Ken in AZ
07-07-2006 16:00:55
 Re: Case serial # VO4522891 in reply to Glenn Norwood, 07-07-2006 13:11:25
Sounds like you might have a VO (V Orchard model) from the VO in the serial number. This seems to be confirmed by the flathead engine. Orchard models with sheet metal aren"t common. The 45 in VO4522891 is the year code... take 4 away from the first 2 numbers. 45-4=41, the year it was made
Sounds like a good find.
Ken in AZ
dctom
07-07-2006 15:55:10
your tractor is a 1941 VO they were only made 2 1/2 years and the orchards have to be rare good luck with it tom
jal-SD
07-07-2006 14:57:40
Does it have a flat-head Continental or a OHV Case engine? If its a Continental, its probably a "V" series, built before the VA series. Easiest way to tell from a distance is to look to see if the exhaust & intake are on opposite sides of the hood. Its probably pretty rare, if its a "VO" w/attached sheet metal, not many made-the "V" series have the lowest production #'s of any of the flambeau red tractors & probably not many "O's" have survived. We have a VC w/continental, serial # VC4524703, its a '41. (My $0.02 worth. jal-SD)
07-07-2006 15:36:05
 Re: Case serial # VO4522891 in reply to jal-SD, 07-07-2006 14:57:40
Thank for the reply. So the vo in the serial # means what. I will have to look but I believe the engine is a flathead. Talk to you later. Glen
