Case VAC-14 side gear (final drive pinion gear)
Jerry in Idaho
07-05-2006 21:42:27
I'm restoring a 1954 Case VAC-14 and need a 12 tooth side gear (final drive pinion). Does anyone out there know where I can find one? Thanks...
J Heitkemper
07-12-2006 18:30:57
 Re: Case VAC-14 side gear (final drive pinion gear in reply to Jerry in Idaho, 07-05-2006 21:42:27
Jerry ,,Not sure if this helps , I have a late VAC rearend Parted out ...It has 3 pt ,,Not sure if the serial # at this time ,,Will check if you can give me the right # needed ,,, Gotta unbolt everything otherwise ,,Jim
Jerry in Idaho
07-14-2006 06:41:03
 Re: Case VAC-14 side gear (final drive pinion gear in reply to J Heitkemper , 07-12-2006 18:30:57
Thanks for your reply. The part number, according to my book, is VTA3295. I could not find a part number on the actual side gear. It appears from the parts book I have that any late model tractor with DRUM TYPE brakes and a 12 tooth gear will have this part number side gear in it. So, without disassembly, the existence of drum brakes would be the identifier.
If it'll help, we could email or fax you the diagram from the book. Thanks again, and I hope to hear from you.
