SC ingine trouble
Hand Crank
07-05-2006 19:33:10
Just picked up a 1952 SC & the 3rd & 4th cyl`s are not fireing.This is all new to me.Where is a good place to start? Thank`s in advance, Don.
oldcraneguy
07-05-2006 20:50:07
 Re: SC ingine trouble in reply to Hand Crank, 07-05-2006 19:33:10
Id start out checking spark at the plugs, a #2 phillips head usually fits the wire pretty well, held a quarter inch or so away from the head while cranking. If youve got spark there Id swap the two wires in case they somehow got crossed. If they still dont hit its time to pull the plugs if theyre wet or oily looking or carboned up very much replace em. and Im guessing you prob dont have a compression tester so your gonna need to buy or borrow one cause I doubt you can get your thumb in far enough to seal the hole and its not the best indicator anyway.
Im not sure what your compression should be but most engines Ive worked on will still fire well down into the 60 lb range although Im guessin 85-100 is more what your hopin for...If copression is very low and pretty much the same on both cylinders youve prob got a blown head gasket... Thats the way Id deal with it anyway, good luck.
P.S. oh almost forgot, keep yer fingers well away from the screwdriver shaft when checkin spark, they'll Bite!
Walt Daviesq
07-05-2006 20:43:33
Take the wire off of #4 plug hold it tight in left hand while holding the right hand on the engine if you get knocked off your feet then proceed to next step.
Really run the engine and hold the wire of # 4 and then 3 close the engine it should jump spark about 1/2 in if you have a mag 3/8 if distributor and it should be blue in color. you can use a pair of rubber handle plier if the wires are old but they should not hurt you if they are in good shape and you don't touch the metal part.
If you have good spark then proceed to the spark plugs get 4 new ones. if they are black and wet you are not getting spark at the plugs if dry and clean you are not getting fuel. From this you should be able to figure out what is needed to fix it.
Walt
Don't be shy to ask more question with what you find out.
