Case 530 backhoe problems...
Joel C. - WA
07-05-2006 09:58:07
The hoe on my 530 quit while using it yesterday. The legs and the loader still work, and when you pull the levers on the hoe it sounds like it's loading the pump, but other than a little wiggle out of the bucket, nothing! The backhoe isn't covered in the manual, and I don't know a lot about troubleshooting hydraulics. The bucket's in a hole so I can't move it until I fix it. Any knowledgable advice would be appreciated! Thanks
Triplerange
07-05-2006 12:10:37
 Re: Case 530 backhoe problems... in reply to Joel C. - WA, 07-05-2006 09:58:07
The bucket's in the hole? Are you trying to pull out a sewer main or something? j/k. Check to make sure you don't have the hoe stuck. Sounds like the oil is bypassing through the relief valve for some reason. It's possible the relief valve just went bad. With Hydraulics it's best to start with the easy stuff first. Check fluid level and change the filters. Check for blown hoses and loose plugs. Good luck.
