Case oil filter
fredct
07-03-2006 10:54:40
I still need help with the bracket for the optional oil filter on my 44 SC. I would be very grateful if someone could post a picture of HOW and WHERE the Filter should mount. I know that it generally went over the starter but none of my manuals show enough detail to show how it mounts. Thanks, Fredct
C. Amick
07-13-2006 09:23:20
 Re: Case oil filter in reply to fredct, 07-03-2006 10:54:40
Are you sure your block is tapped for mounting the oil filter and tapped for the oil line? As you are facing the magneto side of the the block, the filter mounts toward the rear end of the block almost at the same height as the magneto.
Walt Davies
07-05-2006 20:24:09
My 43 Case SI had a filter it bolted right to the block from the bracket on the back of the filter.
Walt
Ken in AZ
07-03-2006 14:19:00
Case had a flange (well, flat spot in the block casting) and some holes drilled in the block for the oil filter (at least on the D series) that the earlier tractors did not have. Sure, it was offered in the books but some just weren"t made to accomodate a filter. I have a couple of later models that have the filter and some earlier ones that list it as an option, but the block is slightly different.
I decided that it wasn"t worth the effort to add the filter; the engine had lasted 60+ years without it so far. I"ll just make a note to change the oil a little more often than I would otherwise.
Probably not what you wanted to hear.
Ken in AZ
dctom
07-03-2006 11:37:46
It probley never had one from the factory, most case didnt untill about 1948
Fredct
07-03-2006 13:07:11
 Re: Case oil filter in reply to dctom, 07-03-2006 11:37:46
I have seen the same type of filter in the photo archives and, it is the same one in my parts manual so I am sure it is factory and I know that it was an option. It is the exact one that I can see in my service manual - I just can't for the life of me figer out how it mounts. Thanks, Fredct.
