Case 2090 Hyd. oil leak
Tom Haws
07-03-2006 08:59:09
Case 2090, w/Power Shift, 3130 hrs., developed oil leak (hydraulic) at torque tube/engine junction. At times oil is apparently picked up by starter ring gear and slung through opening to solenoid plunger and out around dust boot.
Lost approx 1.5 gal. in 2 hrs of light duty work.
All hydraulics, PTO, lift, steering, power shift operate normally. Will appreciate any information.
WBWi
07-03-2006 13:21:28
 Re: Case 2090 Hyd. oil leak in reply to Tom Haws, 07-03-2006 08:59:09
The torque tube or bell housing does have oil in it on the 90 series Case powershifts. The starter has an oil seal in them to keep the starter itslf dry. You may need to replace the seal and solenoid dust boot but first I would look at the Transmission breather to make sure it"s clean.
