Year model ????? V series
toomanycases
07-02-2006 22:31:21
Hi, I need help! Just had a 39 - 41 V brought home. NO serial plate. Is there anywhere on this model you can find a serial #? Rowcrop front. Tires are 9.50 X 32 rear & 5.50 X 15 fronts. It has a flathead engine, wico magneto, different type of power lift on the back (has a round rod pushing up to a flat bar on a pivot, real heavy duty mounting brackets), brakes are located inside of the rear axle housing, (guess I have to pull both housing to work on brakes) Closest picture I can find is in Full Steam ahead on page 206 & 208, engine casting number is F400A429, one in book is F400A418 (p208). 3 piece hood that bolts on(need new ones or will make them). Anyway I need to find out what type so I can try to get parts manual & operating book. Oh yeah mag is fouled up so I can't run it yet. Any and all help is greatly appreciated. I remember looking at these when we went to the Case dealer in 1940 or 41 (ended up with a new 42 SC) because they were so small & had a gas pedal instead of a throttle, & I was trying to figure out how I could stand up when plowing & hold the gas peddle down. Chuck
toomanycases
07-03-2006 14:20:00
 Re: Year model ????? V series in reply to toomanycases, 07-02-2006 22:31:21
Hi Gene,thanks for the information. It will make it easier figuring that it is a 42 model V. Now if I can get a manual or two to start on it. I figure I will have to have the sheet metal custom made. It is just rotted out in too many places. At least I have parts of a pattern to use. Thanks again. Chuck
wilson
07-03-2006 06:55:15
Chuck good to see you out collecting again Any time frame on those in colorado and the c c parts in fort morgan ???
Gene Dotson
07-03-2006 04:03:23
Chuck;
Sounds like you have a 1942 model. The "40 and "41 model had band type brakes and the "42 model had disc brakes. Band brakes had a lever mechanism outside on the front of the housing and later disc brakes has the brake rod going into the housing.
Edison Splitdorf was the most common magneto on the Continental engine used in these tractors, but a variety of other ignition systems were used on them. A FMJ4 magneto works fine on it. Good sheet metal is almost non existant for these tractors... Gene
