Case 411 B-H
ins2g8r
07-02-2006 14:24:37
Anyone know if there is a way to install power steering on a 1958 Case 411 b? Just bought it, like it, but needs some other help as well, drive fluid is somehow getting into the crankcase, and the eagle hitch arms leak down, first tractor I ever had, any help is welcome, thanks.
Camboted
07-02-2006 17:25:13
 Re: Case 411 B-H in reply to ins2g8r, 07-02-2006 14:24:37
Yes, I think the early 400's used a Char-Lynn "torque enhancer" (just like the power steering used on an IH-M). You'll need to make a simple bracket. It gets mounted on the steering shaft near the rear of the engine. You need a pump which can be mounted by adding a second generator pulley, or running it off the back of the generator. I think they work better than the later Case design and much simpler to work on.
