2670 paint.,
kirk in ks,
07-01-2006 12:36:20
I have a 76 2670,
and I wanna paint the frame power red again,
It has some places that,s it,s worn off on,to the metal,
so do i sand it, and spray two coat,s on it, or do i just use the paint on it and ruff it up a little then go over the top with new paint
c hess
07-02-2006 17:32:31
 Re: 2670 paint., in reply to kirk in ks,, 07-01-2006 12:36:20
There is aforum called ---paint@ bodywork---you can go to an they can tellall you need todo. I can tell you you will need to rough up paint an clean clean clean than cover with primer an paint if you are going to farm with it.If you want it for a show tractor that is a whole lot different an you need to read on forum how to paint it. Keep in mind paint dust has lead in it . As for paint i would use genuine case products including hardner. Do follow safety instructions
