930 Ck Smokes
R.Jones93
09-15-2006 07:03:23
We recently bought a 930CK desiel. We aren't new to the 930s, but this ones a little different. It smokes blue smoke while working it. We did put in a head gasket after we bought it. Could we have missed something? We worked it for about 20 hours on the feed mill and round baler and it used about a quart of oil. We do know the engine had a major over haul in the mid 80s. Right know were checking to make sure there are no obtruction in the air breather, but I keep reading about these o-rings on the head. I don't remember seeing these. Where are they and could they be the problem. Thanks in advance.
Doc Larry
09-16-2006 19:03:43
 Re: 930 Ck Smokes in reply to R.Jones93, 09-15-2006 07:03:23
Most oil consumption is either around the rings or through the valve stems.
If you are otherwise happy with the way your 930 runs, I don"t think I would worry about a quart every 20 hours. You can buy a lot of oil before you spend as much as you probably will for the cost of repairs.
But if you like to work on engines that"s a whole "nother story.
Larry
CNESLER
09-15-2006 17:14:40
The seals look like rubber washers
and I think they are to seal the water side of the head. Blue somke is oil or fuel. White smoke is water. Worn sleeves could cause this smoke.
Good Luck
CNESLER
