WD45 Hydraulic pressure
doorman
01-01-2008 19:29:07
I just bought a WD45 with a front mounted push blade. It has two lift cylinders controled by a "joystick" valve. The lift moves very slowly up or down. Is this normal? The 3 point lift seems to work normally. Is this a case of adequate pressure, but not enough volume? Thanks doorman.
CWL
01-02-2008 08:21:42
 Re: WD45 Hydraulic pressure in reply to doorman, 01-01-2008 19:29:07
Any chance of seeing a picture of this setup? I have toyed with the idea of building a front blade to go on my WD, but I've never gotten around to actually doing anything.
old
01-02-2008 09:11:12
 Re: WD45 Hydraulic pressure in reply to CWL, 01-02-2008 08:21:42
I have a set up like that on my C. I built it from pictures Rod sent me but it could also be built to fit a WD pretty easy. I have it set up to lift a 7 foot blade which is really way to much for a C but it was a fun thing to build and I use it off and on all the time to help unload heavy stuff. It will lift around 500lbs
JMS/.MN
01-02-2008 08:17:35
If you are using the tractor"s internal hydraulics, it is like old said. An option you have is to add a reservoir and front mount pump of 15-1800 psi, higher volume- let"s say 18-20 gpm (AC is about 7 gpm). Then you"d have independent hydraulics for whatever use you want, plus retain the AC 3000psi system for its own use.
old
01-01-2008 21:38:32
Most Allis tractors use a high pressure low GPM system so yes they will be slow.
