WD45 vs D17 vs 170 vs 175
jhb
12-30-2007 05:41:36
Will an engine from a D17, 170 or 175 fit in a WD45 without a lot of modifications? Or are only certain parts exchangeable?
ohio
12-30-2007 16:26:26
 Re: WD45 vs D17 vs 170 vs 175 in reply to jhb, 12-30-2007 05:41:36
The crank will need spotted for the locking bolt in the pulley, and the pulley will need a keyway broached in. One oil line to the filter will need rerouted to clear the steering. You'll need a water pump from a wc-wd-wd45 with the mounting holes opened up to 15/32" Gleaner "e" engine was only gov'd @ high idle, so you'd need a gov. assy. from a tractor, as well as the fuel pump block off.
magg
12-31-2007 16:06:01
 Re: WD45 vs D17 vs 170 vs 175 in reply to ohio, 12-30-2007 16:26:26
An E- gleaner engine has a more responsive gov. than any tractor because a combine has to turn at a set speed no matter what load is put on it...leave the gov. alone & tractor won't lose RPM's under load...Marvin
ohio
12-31-2007 17:35:14
 Re: WD45 vs D17 vs 170 vs 175 in reply to magg, 12-31-2007 16:06:01
But it won't govern @ 1/2 throttle, 2/3 throttle, ect. My gleaner engine is in my primary tractor for working ground, making hay, snow plowing ect. I have to be able to put it into 3rd gear just above an idle and rake hay, or 1/2 throttle to disk..... ..... ..... ..... ..
magg
01-01-2008 17:32:33
 Re: WD45 vs D17 vs 170 vs 175 in reply to ohio, 12-31-2007 17:35:14
Don't know where you learned to drive a tractor but the proper way is wide open trottle & change gears to the right speed...have farmed for 50 yrs & running a tractor at half speed or over geared is the worst thing you can do to it...by the way the combine gov. will WORK at any engine speed...have a WD-45 with E engine that I work my garden with...take care
ohio
12-30-2007 16:32:29
This is assuming gas engine. The 17's had a 6 cyl. diesel that will bolt in (more or less) with some wd45 diesel parts. the 4-236 perkins in the 170-175 would prolly not fit, and would be high $, as well as not being as powerful as the gasser. For the same $ and effort, a 4bt cummins could be fit.
big jt
12-30-2007 14:58:04
Gassers should all mix and match. WD and WC will work also.
the D17 and later had a adapter plate for the bellhousing, might run into a issue on the crank pulley and a few things like that but no biggies.
E gleaner will also work but a few more issues the governor being the main one.
jt
old
12-30-2007 08:35:37
An engine from a D-17 will fit but I'm not sure what all it takes to do so. I just have read here a few times that it will
JMS/.MN
12-30-2007 10:46:11
 Re: WD45 vs D17 vs 170 vs 175 in reply to old, 12-30-2007 08:35:37
I believe it should bolt right in. E combine had the same basic engine as the D17- putting that into a tractor, there is the issue with an unneeded fuel pump on the combine engine- needs to be removed and a cover put over the mounting hole. Not sure about issues with a governor and front crank pulley.
